LMS 3.2 licensing
Have installed licenced version of lms 3.2 in a server and installed evaluated version of 3.2 in a virtual server. Is it possible to take the license from the server to the virtual server and if possible how to migrate?
1 REPLY
Re: LMS 3.2 licensing
If you want to move the license form the physical server to the virtual server, you need to have the original license file as provided by cisco (with a name similar to this: LMS20070201015953596.lic)
- Copy this file to your virtual server in any directory you want but NOT into NMSROOT\etc\licenses
- go to Common Services > Server > Admin > Licensing and point it to the file to license your installation
- logout and close all broser windows, relogin to LMS and you should have the virutal server licensed
If this is working remove the license from the physical server; I do not know if you want to keep the physical server running with the eval license. If yes, you can try the following procedure which definitley removes your license but I only assume that it will keep your eval license - I have never reverted a licensed installation to an eval...
on the physical LMS server go to NMSROOT\etc\licenses
- all files ending with .lic are plain text files
- KEEP only those xxx.lic files that does have a line like the following:
        NOTICE="0 \
        dummyPak" SIGN=77A562D42CF8
(there is no value between the tags and there is a "dummyPAK" between the tags)
- delete or move away the other xxx.lic files
- restart the LicenseServer with
    pdterm LicenseServer
    pdexec LicenseServer
- login to LMS an verify the result in Common Service > Server > Admin > Licensing
184
