LMS 3.2, SNMP V3, CDP Neighbors, CM Topo View
Running LMS 3.2, (CM 5.2.0), SNMP V3 - After a power outage that exhausted the UPSs for a 6509 (running native sup-bootflash:s72033-adventerprisek9_wan-mz.122-33.SXH6.bin), the 6509 was dropped from the Topology map.  It had been discovered (SNMP V2c) prior to switching to SNMP V3.  Is there a "context" statement required to allow CDP neighbors to be retrieved?  Other newly added devices also fail to appear in the topology map, yet are in the DCR.  Device Center show no CDP neighbors for these newly added devices.
thanks in advance for any help...
craig
Re: LMS 3.2, SNMP V3, CDP Neighbors, CM Topo View
Just a quick question (and it doesn't pertain to a fix for your problem).  What version of Java are you using?
Chris;
   current version of Java is 1.6.0 Update 20
Additional information to the issue:  a WS-C3750 has been discovered (connected to another 6509 that is running hybrid) and added to the topology map as it one would expect.
craig
403
