LMS 3.2 upgrade failure?
I upgrade to LMS3.2 from 3.0.1 and now I don't see TAB for
Common Services, I see a new TAB "setup Center" but no TAB for CS where
I can click device discovery etc. Attached is the screen shot
Re: LMS 3.2 upgrade failure?
Anyone have clue, How do I get the CS back?
Where is your screenshot?
Can you provide more information about your issue?
I think my upg, rade failed with tons of errors: don't understand why I got this error though while my cluster patch is up to date (I'm on Solaris 10)
WARNING: Ensure that you have installed the recommended Solaris 10 cluster patches released
WARNING: on Apr/17/07, in this server.
I also tons of errors for the following, im copying only the few.
WARNING: Exiting installation beyond this point might result in system instability.
ERROR: The following base package image is bad: CSCOsjre.
ERROR: The following base package image is bad: CSCOmd.
ERROR: The following base package image is bad: CSCOcsjre.
ERROR: The following base package image is bad: CSCOperl.
ERROR: The following base package image is bad: CSCOxml4j.
ERROR: The following base package image is bad: CSCOhlp.
ERROR: The following base package image is bad: CSCOxsl.
ERROR: The following base package image is bad: CSCOjcht.
ERROR: The following base package image is bad: CSCOcam.
ERROR: The following base package image is bad: CSCOxrts.
ERROR: The following base package image is bad: CSCOsnmp.
ERROR: The following base package image is bad: CSCOjgl.
ERROR: The following base package image is bad: CSCOplug.
ERROR: The following base package image is bad: CSCOdb.
ERROR: The following base package image is bad: CSCOcsorb.
I'm getting ready to do the install again, I have increased the swap file size to 10GB and disk space to 40 GB, any other suggestion before I try this again?
Make sure you are installing from the DVD media
240
