07-27-2010 02:05 AM
I have got LMS3.2 with RME 4.2.0. When I do inventory colection for the device added to this, the job fails with different error coded. I can list a few here...
1. 7206vxr running 12.4(25)b and 6509 with 12.2(18)sxf13a failed with error "RICS0001:internal error,unable to process the collected data from the device"
2. 4505 switch running 8.4(11)GLX failed with error "device sensed but collection failed.
I would like to know, is there any bug hitting on these...
Are the bug ids CSCsv65621, and CSCeb51407 applicable to my scenario...
Solved! Go to Solution.
07-29-2010 03:56 PM
LMS 3.2 ships with RME 4.3, not 4.2. What is your exact version of RME? Post the IC_Server.log after reproducing one of the collection failures.
07-29-2010 03:56 PM
07-30-2010 09:51 AM
Thanks a lot.. i could find out the snmp time out happening and i increased the same. now the inventry colection is successful...
Thank You...
