Community Member
LMS 3.2
When i try to stop the daemon i get the application error attached.
1 ACCEPTED SOLUTION
Re: LMS 3.2
Try:
C:\CSCta56151>D:\Progra~1\CSCOpx\bin\perl CSCta56151-0.pl
This should work assuming you extracted the patch under C:\CSCta56151.
Community Member
Re: LMS 3.2
Hello
Can anybody help me for the error attached in above mail
Re: LMS 3.2
This will probably get fixed by applying the DFM 3.2 consolidated patch.  You are looking for the patch ID CSCta56151.
Download here
Community Member
Re: LMS 3.2
How i have to install the file,i think it is not a double click.
Re: LMS 3.2
The install instructions are in the readme file within the .tar file.
Community Member
Re: LMS 3.2
Hello Dear,
Here is the command
C:\CSCta56151>D:/program Files/CSCOpx/bin/perl/CSCta56151-0.pl
'D:/program' is not recognized as an internal or external command,operable program or batch file.
Cisco Works LMS is installed in D:\program Files\CSCOpx. And i have kept the patch file in C:
What will be the command.
Re: LMS 3.2
Try:
314
