LMS 3 -ipa sla
While configuring the source router, the ip sla monitor command requires additional commands.
Where can i can find the exact command
1 ACCEPTED SOLUTION
Re: LMS 3 -ipa sla
Yes, SNMPv3 is supported. It would help to see the configuration and show ver from this device.
Re: LMS 3 -ipa sla
What exactly do you want to do? If you're using IPM, then IPM will do all of the setup for you. All you need is SNMP read-write credentials on the device. The only thing you may want to configure is the IP SLA responder. That command is simply:
ip sla monitor responder
Re: LMS 3 -ipa sla
I am using snmp v3 read and write view on the router and the IP SLA does not see the router as possible source.
Does it support v3 or just v2
Re: LMS 3 -ipa sla
143
