LMS 3 -IPM -IP SLA
I have a router in the DCR which supports IP SLA, IP Adv Services 12.4 ..
and SNMP v3 configured as read and write view mib-2 included.
When i import it into the IPM, it detects it as not IP-SLA enabled.
If there is anything else I need to do
1 ACCEPTED SOLUTION
Re: LMS 3 -IPM -IP SLA
mib2 view is not sufficient. Try using the built-in v1default view instead.
Thank very much, your solution solved my problem. The IPM now recognizes the router as IP SLA enabled.
Great job.
Cheers,
Ashley
118
