LMS 3 on VM-ware
Did anyone try to upgrade Ciscoworks 2.6 to ver 3.0 on VM-ware? I tried it with dummy data and it worked fine, but with a copy of the actual ciscoworks server (with 6Gb of data) it is giving errors during the intsallation. I noticed that the documentation says that it is not supported - does this mean that Cisco will not provide support or that it will not work ?
1 REPLY
Blue
Re: LMS 3 on VM-ware
Try LMS 3.0.1 that's supported, then you can open TAC cases if there's any issue.
127
