05-19-2008 01:46 AM
Hi, I am running CM without CDP.
I wanted to know if I can access VTP reports for the switches without the topology services.
Thx
05-19-2008 08:25 AM
No. VTP reports are tied to Campus. No other application has that kind of VTP/VLAN view of the devices.
That said, if you have the VTP domain configured in the devices' running configs, you can use RME's Search Archive By Pattern feature to find the VTP domains of various devices.
05-19-2008 08:37 AM
Sorry,
I meant STP reports on the Switch Cloud.
05-19-2008 09:01 AM
You'll need CDP to make this truly effective.
