11-21-2010 11:26 PM
I have installed a new version of CiscoWorks LMS 4.0.
I would like to forward certain SNMP traps to another server. Not all traps but only the traps of devices which are down.
Is it possible to filter the traps and then forward the traps who match the filter to a server?
Best Regards,
Joris
11-21-2010 11:45 PM
If you enable trap forwarding in LMS, all traps received by LMS will be forwarded to the external NMS.
You can, however, look at NMSROOT/objects/smarts/conf/trapd/trapd.conf. You can modify this file to specify exactly what traps to forward. The comments in the file should help you figure out the syntax. However, direct modification of this file is not supported by TAC, so be sure to save a backup just in case.
11-22-2010 12:00 AM
Hello Joseph,
I will do some testing adjusting this file.
Too bad it is not supported by Cisco Tac.
Thank you for your quick reply...
Best Regards,
joris
