LMS 4.1 alerts on unused sereal interfaces
Greetings,
I have been getting alerts on unused serial ports on my routers as being operational down.  How can I stop these alerts?  Thank you.
Phil.
Put the interfaces admin down and let DFM/faultmanagment rediscover the devices.
Cheers,
Michel
Is there any other way, than this?  Most of these serial interfaces can not be configured.  When I try to access the interface I do get the following:
xxxxx(config)#int se0/0/0:5
%Cannot access B-channel interfaces
Thanks.
Phil.
Yes Phil,
I tell fault management not to manage the individual pri or bri channels.
https://supportforums.cisco.com/message/3484898#3484898
This however cant be done via the gui but via one of its configuration files.
Cheers,
Michel
Michel,
I added the following to the tpmfr.* file, stoped and started the crmdmgtd and removed and added the device without and success:
#This is an example of how to restrict the creation of ports for a
#specific sysObjectId based on the ifType:
#IFTypePattern-SwitchPort.1.3.6.1.4.1.9.1.501 53
#Stop monitoring the serial B-Channel on 2821,3925,2921 and 2911
IFDescrPattern-.1.3.6.1.4.1.9.1.577 ~Bearer Channel*
IFDescrPattern-.1.3.6.1.4.1.9.1.1042 ~Bearer Channel*
IFDescrPattern-.1.3.6.1.4.1.9.1.1044 ~Bearer Channel*
IFDescrPattern-.1.3.6.1.4.1.9.1.1045 ~Bearer Channel*
# Add Fiber Channel port (56) for MDS devices
Actually I messed arround with that for a while. Try this for the various device sysobjectid's
IFDescrPattern-.1.3.6.1.4.1.9.1.577 ~Bearer*
I think it failed over the space in the pattern
Cheers,
Michel
615
