Community Member
LMS 4.1 Configuration Fetch Problem
I have some problem with WS-C4006 Cisco Catalyst that lms doesn't collect and put into "never collected" area. I also see that those devices doesn't show the classic prompt ">" and "#". Could be the main problem ? If yes how can configure LMS to recognize a different prompt for devices.
If no what could be the problem ?
Many thanks
1 REPLY
Blue
You can add your custom prompts into /opt/CSCOpx/objects/cmf/data/TacacsPrompts.ini. No restart of LMS is required for the addition to be recognized.
377
