LMS 4.1 softwer distribution
We tried to distribute the softwer ( 12.4.23 ) via LMS 4.1 but we got the following message:
Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP
SWIM1001: The input parameters to the Image Distribution/Image Import/Image Activate are invalid.
You may have used incorrect Device Data for this task.
Check the application log file for more details.
Device is unlocked.
Device Upgrade Result : Failed
End Time:Mon Mar 05 15:53:17 CET 2012
Earlier we used LMS 3.2 and it gave same messages!
The hardver is cisco 2620XM and actually used IOS is
c2600-advipservicesk9-mz.124-3.bin
We need to upgrade large number of devices via LMS.
Silver
You can try deleting the image from your repository and then re-adding it.  If this does not correct the problem then please try deleting the device from LMS and then re-adding it.  However if the issue persists, the job logs will be helpful to further troubleshoot.  You can find them (Windows)  C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\
The lms 4.1 isbtrand newe install!
Therer are more than 1200 devices and i would not like to delete them.
I enclosed the jobs logs.
If nobody has idea i need to open TAC!
The job swim_debug.log shows
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition,operationStatusChange,320,FLASH_SQUEEZE : failed ,but updating flash partition as delete command may got succeded
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition,UpdateFlashPartition,208,Updating the flash partition "flash" after an erase/squeeze operation
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition,UpdateFlashPartition,211,Got source object as com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashSourceCFM@898b41
[ Mon Mar 05  15:53:08 CET 2012 ],ERROR,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper,run,385,Caught exceptionjava.lang.NumberFormatException: For input string: "NoSuchInstance"
    at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
    at java.lang.Integer.parseInt(Integer.java:449)
    at java.lang.Integer.parseInt(Integer.java:499)
    at com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition.UpdateFlashPartition(FlashPartition.java:216)
    at com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition.operationStatusChange(FlashPartition.java:321)
    at com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashSourceCFM$OperationThread.run(FlashSourceCFM.java:1864)
    at com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashSourceCFM.squeeze(FlashSourceCFM.java:1070)
    at com.cisco.nm.xms.xdi.pkgs.LibSwim.flash.FlashPartition.squeeze(FlashPartition.java:543)
    at com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RfrSwLoadOperation.performFlashCleanup(RfrSwLoadOperation.java:3491)
    at com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RfrSwLoadOperation.performFlashCheckup(RfrSwLoadOperation.java:3249)
    at com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RfrSwLoadOperation.run(RfrSwLoadOperation.java:1120)
    at com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RfrSwLoadOperation.execute(RfrSwLoadOperation.java:366)
    at com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper.run(RFRDistributionOper.java:374)
    at java.lang.Thread.run(Thread.java:662)
[ Mon Mar 05  15:53:08 CET 2012 ],ERROR,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper,run,388,Unable to Initiate an Image Copy Operation to Device
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper,updateStatus,343,updateStatus() protocolUsed
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper,updateStatus,346,Buff Msg:
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.rmeng.swim.drivers.SoftwareOperationDriver,operationStatusChange,2000,DDriver :opStatusChnage got Operation Status : Op ID = 2364641593518593493, Error Code = 0, Error Info = Unable to Initiate a image distribution Operation, Error Detail = Check the input parameters, Percentage Completed = 0 , Status =  FAILURE, Operation Failed
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.rmeng.swim.drivers.SoftwareOperationDriver,operationStatusChange,2001,Protcol used
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.rmeng.swim.drivers.SoftwareOperationDriver,operationStatusChange,2010,OSC null
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.rmeng.swim.drivers.SoftwareOperationDriver,operationStatusChange,2011,
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.rmeng.swim.drivers.SoftwareOperationDriver,operationStatusChange,2018,OSC null
[ Mon Mar 05  15:53:08 CET 2012 ],INFO ,[RFRDOper:172.36.16.254],com.cisco.nm.xms.xdi.pkgs.SharedSwimIOS.RFRDistributionOper,updateStatus,346,Buff Msg: SWIM1001: The input parameters to the Image Distribution/Image Import/Image Activate are invalid.
Silver
Hey,
I see in the logs you are upgrading to c2600-advipservicesk9-mz.124-23.bin but the only release I see available on CEC is c2600-advipservicesk9-mz.124-23a.bin.
Please verify that the image is valid and try again.  Let us know if you still run into any issues.
http://www.cisco.com/en/US/products/ps6350/prod_release_notes_list.html
612
