LMS 4.1 SystemPsirtJob failing
Hello community,
we are running LMS4.1 on a Windows Server and the SystemPsirtJob keeps failing. I have checked to see if there is connectivity to the Cisco site, by downloading device packages and that seems to be working fine.
How can I troubleshoot the above issue?
Thank you in advance,
Katerina
AFROJ AHMAD
Hi Katerina,
there could be any reason of the failure  like blocked http, https and ftp for cco.cisco.com.
Can you try to generate the reports locally instaead of cisco.com , check the below link with detailed steps:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/collection.html#wp1168106
hope it will help
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Katerina,
hope it will help
Thanks-
Afroz
Thanks for your reply!
I was able to generate the reports locally. Now I just need to troubleshoot to see why I can't get the LMS server to download them.
Thank you so much!
