LMS 4.1 Unknown device
We are running LMS 4.1 and we have more than 150 devices.
LMS could not find the fault discovery for 3 switches with partnumber WS-C3560C-12PC-S. This switches are considered as unknown.
Ios version is c3560c405-universalk9-mz.122-55.EX3.bin
But other things are ok. Inventory Collection ,Config Archive,  Topology Data Collection etc .  Is there any way to fix ths issue?
We have compact switch WS-C3560CG-8PC-S, which is working perfectly for all  features.
Is there any way to fix this issue?
Thanks in advance
Everyone's tags (5)
As per the supported device list for LMS 4.1 the above devices are supported for fault management.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html#Cisco Catalyst 3560-C Series Switches
Try updating the device packages for Fault management as well and resubmit the devices in FM.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hai,
Fault dicovery issue is the only issue on WS-C3560C-12PC-S with ios version is c3560c405-universalk9-mz.122-55.EX3.bin
It works with  Inventory Collection ,Config Archive,  Topology Data Collection etc .
We have compact switch WS-C3560CG-8PC-S, has image c3560c405ex-universalk9-mz.122-55.EX2 works fine
We cannot use this image for WS-C3560C-12PC-S.Is there any other images that we ca apply for this switches.
How we can update the device packages for Fault management?
Thanks in advance
Sreelal
Admin -> System -> Software Center -> Device Update
Following the documenation below regarding "Performing Device Update":
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/admin/swcenter.html#wp1096972
-Thanks
I had the same problem with a switch WS-C3560X-24P-S with IOS 12.2(55)SE3 .
After some analyses, I can see that the problem came after I applied the patch :
lms41-Linux-Bundled-Patch-March2012-0
To resolve this issue, I installed the Device Update "FaultManagementDeviceUpdates41.LMS41.v4-0". After installation, the switch was still in "unknown" state. I unmanaged / managed the device and then finally the DFM recognized the switch.
Cheers
693
