06-14-2012 02:30 PM
Hi Everybody,
After an upgrade from LMS 4.2 to 4.2.1 Legacy menu is completly empty. Anyone resolved this? Is it a bug?
If it's empty, how to get to some of DFM options (like rediscovery, discovery status etc.) They seem not present in "Site map".
Greets,
Tomek
06-18-2012 08:38 AM
We have exactly the same problem, any solution for that?
06-27-2012 01:48 AM
Hi, yes - there is a simple solution: clear cache and cookies in your browser. It should work in any browser you use.
06-27-2012 06:04 AM
Yep, this is true. Something else you can try is to simply click in the blank panel. However, the clear cache is the best choice.
06-28-2012 12:45 AM
In our case, clicking the blank panel did not work. Despite the fact that clearing the cache is working solution, the menu content appear with noticeable lag (1-3 seconds). This did not happen in 4.2.
