LMS 4.2.4: Device Performance Management Summary is temporarily unavailable.
Tobias Heisele
has anyone an idea what that message means? All processes are running fine and I can't find that error message in any log or documentation.
8 Replies 8
Vinod Arya
May be temporary. Did you tried daemon manager restart?
Please share screenshot and details on what exactly you're trying to do, when you get this error.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
To restart the daemon manager, I have to wait for the next maintenance window.
Any idea to investigate the error to avoid its return?
Reasons are unknown on almost all SRs I have seen with this issue. As performace portion doesnt have much data, reinitialize is the easiest option, done in seconds.
But that would too, require daemon restart. you can Share upm_ui.log, upmprocess.log, upmdbmonitor.log from NMSROOT/log and NMSROOTdatabases\upm\upm.log.
-Thanks
Vinod
Would not reinitializing the db clear all data?
Yes it does, but for the specific module, just performence, which means loosing custom templates, but you can export important one's.
Not any other details from LMS.
-Thanks
Vinod
Vinod Arya
I have seens some of the older issues in LMS 4.2.2 as well as 4.2.3, and the issue came out to be corrupt DB for Performance Management portion of LMS. Was fixed with the DB reinitialization.
You may have to follow the same path if restart doesnt help.
-Thanks
Daemon manager restart did not help, but UPM DB process is running fine:
pdshow UPMDbEngine
    Process= UPMDbEngine
    State  = Program started - No mgt msgs received
    Pid    = 34732
    RC     = 0
    Signo  = 0
    Start  = 1/22/2014 12:37:57 AM
    Stop   = Not applicable
    Core   = Not applicable
    Info   = Application started by administrator request.
Next step is to validate the upm database or to clear the upm db transaction log?
(https://supportforums.cisco.com/docs/DOC-8796)
Though it is time consuming to stop daemon --> do a transaction log receovery --> and restart daemon to check effectiveness, it will be much better to try it once, which has a fair probability of fixing the issue.
Please try following procedure for Transaction log receovery :
Do a trasaction log recovery for all Db's :
     * Goto NMSROOT/databases/upm and remove upm.log file.
     * on command prompt run following command :
dbsrv10 -f  upm.db
Example:
C:\Program Files (x86)\CSCOpx\databases\upm>dir *.log
Volume in drive C has no label.
Volume Serial Number is E492-A3AB
  Directory of C:\Program Files (x86)\CSCOpx\databases\upm
03/27/2012  07:01 AM           196,608 upm.log
               1 File(s)        196,608 bytes
               0 Dir(s)  27,119,108,096 bytes free
C:\Program Files (x86)\CSCOpx\databases\rmeng>del upm.log (you have to delete if from GUI, cli mostly doesnt work)
C:\Program Files (x86)\CSCOpx\databases\rmeng>dbsrv10 -f upm.db
On Solaris, try :
env LD_LIBRARY_PATH=/opt/CSCOpx/objects/db/lib64 /opt/CSCOpx/objects/db/bin64/dbsrv10 -f /opt/CSCOpx/databases/upm/upm.db
Else for reinitialize, following is the command :
Solaris : /opt/CSCOpx/bin/dbRestoreOrig.pl dsn=upm dmprefix=UPM
Windows : NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=upm dmprefix=UPM
-Thanks
Vinod
