LMS 4.2.5 appliance: Auto Allocation Settings not working
I'm in a new install of LMS 4.2, upgraded and patched to 4.2.5
Devices are in the DCR but no devices show up anywhere else.
I went to the Device Administration>Device Allocation Policy and it pops up with an error:
Problem in Policy configuration. Please check the /var/adm/CSCOpx/log/UDM.log log for more details.
I close the popup and try to click enable Auto Mode/Manage All devices and Apply.
This pops up with the same UDM.log error so here are the last few lines.
[ Wed Oct 22 23:21:52 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : No policy is configured
[ Wed Oct 22 23:21:52 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : Screen ID redeirected is udm.policy.management
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : Inside 'Apply' action
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : automanage value is true
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : allocateType is AllDevices
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 getGroupName]  : Going to append the Group ID and Host name.
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : Length of Group Name : 0
[ Wed Oct 22 23:26:13 UTC 2014 ] INFO   [UDMPolicyMgmtAction : TP-Processor5 perform]  : allocateType is all? AllDevices
[ Wed Oct 22 23:26:13 UTC 2014 ] ERROR  [UDMPolicyMgmtAction : TP-Processor5 evaluateCurrentPolicy]  : Exception while applying the selected policy : CSTM Error Code [-3] CSTM Comm Type [0] - CTMServlet::service() : URN not found "UDMExternal"
[ Wed Oct 22 23:26:13 UTC 2014 ] ERROR  [UDMPolicyMgmtAction : TP-Processor5 evaluateCurrentPolicy]  : Exception while applying the selected policy : Exception Stack Trace :
com.cisco.nm.dcr.udm.exception.UDMException: CSTM Error Code [-3] CSTM Comm Type [0] - CTMServlet::service() : URN not found "UDMExternal"
        at com.cisco.nm.dcr.DCRProxy.setPolicyConfiguration(DCRProxy.java:2978)
        at com.cisco.nm.dcr.udm.uii.action.UDMPolicyMgmtAction.evaluateCurrentPolicy(UDMPolicyMgmtAction.java:585)
        at com.cisco.nm.dcr.udm.uii.action.UDMPolicyMgmtAction.perform(UDMPolicyMgmtAction.java:235)
        at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
        at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
        at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
        at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
        at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:311)
        at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
        at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
        at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
        at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
        at java.lang.Thread.run(Thread.java:662)
Hi , Reboot the server once
Hi ,
Reboot the server once and check the issue, looks like service not started properly.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
multiple reboots etc. still
multiple reboots etc. still the same problem
Hi John , If this is a
Hi John ,
If this is a windows server then Stop the LMS service
Open the "services.msc " windows .
Change the startup type of "Cisco works Daemon Manager " to MANUAL from Automatic
Now Reboot the server.
Once server is up
Changed the startup type back to "AUTOMATIC"  and start the LMS services
Thanks-
Afroz
HelloI have a good news for
Hello
I have a good news for you John Paul !!!
Look at this post  https://supportforums.cisco.com/discussion/11516906/all-devices-ist-empty-lms-42 and read MARK BAKER comments
He refers to this BUG
https://tools.cisco.com/bugsearch/bug/CSCue59646
I applied the procedure and now everything is OK
This will take a few minutes
Go at the shell
/etc/init.d/dmgtd stop
rm /opt/CSCOpx/lib/classpath/com/cisco/nm/cwcs/mdf/mdfdata_NonCisco.xml
cd /opt/CSCOpx/lib/classpath/com/cisco/nm/cwcs/mdf/
rename devicedata.xmlmdfdata_NonCisco.xml mdfdata_NonCisco.xml
/etc/init.d/dmgtd start
Wait few minutes
Then go to LMS webadmin : "Inventory > Device allocation Policy "
Select "Enable Auto mode" and "click apply" and it will work again !!!!
Check devices status at "Inventory > Device Administration > Manage Device State"
After I restart a new discovery but it is not necessary
For moment, all seem to be OK
Give me your feedback !!!
Bye
Hi I have the same issue, did
I have the same issue, did you solved it please ?
Many thanks
Gilles
91
