LMS 4.2.5 Netconfig changing port config based on port settings
I am trying to use netconfig to change the port config on my switches. I want to use an adhoc rule to determine if the port already is configured for 802.1x (authentication port-control auto) authentication and then modify those ports to "authentication open".
IS that possible?
Thank you for your reaction?
Robert
1 REPLY
Hi Robert,To check which
Hi Robert,
To check which device have this config , use Baseline Template
check the below link for example and case study.
Hope it will help
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
58
