06-05-2012 03:17 PM
Has anyone seen this?
Backup failed on 2012/06/03 at 22:02:52. REASON: Unable to proceed with the backup operation as some files are being accessed by jobs. Reschedule the jobs such that the backup job does not coincide with other jobs.
Randomly the backup for lms 4.2 is failing. it has suceeded but majority of the time its failing. i have tried changing times but nothing seems to work. previously we were running 4.0.1 and had noproblems with the backup time.
Just found the bug
CSCtz29665
no work around at the moment
08-27-2012 01:59 AM
I see exactly the same issue in 4.2.1
I think we have to wait for Cisco to fix the bug - Hopefully, the solution will be an automatic solving of conflicts, making the manual planning of jobs redundant...
08-27-2012 04:34 PM
I was advised that 4.2.2 should resolve this when it comes out.
08-29-2012 12:52 AM
Yesterday i tried upgrading to 4.2.2, but my backup still failed this morning with the "some files are being accessed by jobs".
I will try to disable/enable the backup job to see if that will make a difference..
08-29-2012 05:03 AM
The Bug # CSCtz29665 is still in open state with LMS 4.2.2 and is not fixed yet, check Release notes for more details. You can try to configure your Server to stop daemon manager before taking backup and start it after backup is done, which would fix the job conflict and backup should succeed!
-Thanks
Vinod
11-05-2012 11:06 PM
Hi vinod,
I am also facing this same problem with lms 4.2.2
Is cisco currently planning to release the fix for this issue ?
what are the files to be copied manually like NMSROOT\databases etc., in case i wish to maintain accurate data ?
11-06-2012 01:18 AM
Hi Rajesh, patch is released on 25-OCT-2012
http://www.cisco.com/cisco/software/release.html?mdfid=284259296&flowid=31102&softwareid=280775103&os=Linux&release=CSCtz29665_4.2.2&relind=AVAILABLE&rellifecycle=&reltype=latest
11-06-2012 01:58 AM
Hi Dejan,
Thanks for the quick update.
Unfortunately the fix is for linux machine. My server is windows....
regards
Rajesh
11-06-2012 02:51 AM
Hi Rajesh,
I downloaded one for Windows (lms4.2.2-win-CSCtz29665-0.zip) last week. I cannot see it now. Maybe someone from Cisco can confirm why is it removed from website?
11-06-2012 02:59 AM
Hi Dejan,
Is it possible to send the file to my email id plz....or can u upload in any of the ftp plz..
11-14-2012 09:34 PM
Hi Dejan,
Could you please tell me how to install this patch file ?? procedure...
regards
Rajesh
11-15-2012 12:34 AM
you have readme file in installation zip (file lms-CSCtz29665.readme)
11-15-2012 01:28 AM
im going to install this now., i wonder whether there wont be any dataloss as cisco is yet not mentioned about this fix ?
11-16-2012 01:39 AM
Hi Dejan,
I am able to do immediate backup now.... Thanks a lot & a ton..i will have to schedule it for tomorrow and check.. initially when we tried, the back was failed 2-3 times after the patch upgrade. But after a couple of minutes again we checked and found to be working fine...
the procedure would be, for example if the patch is in e:\ drive and lms is installed in c:\program files, then...
go to command prompt,
c:\program files\CSCOpx\bin\perl e:\lms4.2.2-win-CSCtz29665-0\CSCtz29665-0\CSCtz29665-0.pl
The services will be stopped, patch will be updated and services will be started automatically.
regards
Rajesh
11-21-2012 01:54 AM
the patch for BugID CSCtz29665 is released here on CCO:
"http://www.cisco.com/cisco/software/release.html?mdfid=284259296&flowid=31102&softwareid=280775103&os=Windows%20CE%202.11&release=CSCtz29665_4.2.2&relind=AVAILABLE&rellifecycle=&reltype=latest"
I do not know whey they opend a new section for Windows CE 2.11, - but on CCO you have to follow this path to find it:
Downloads Home > Products > Network Management and Automation > Routing and Switching Management > Network Management Solutions > Cisco Prime LAN Management Solution > Cisco Prime LAN Management Solution 4.2 > LMS Patches > Windows CE 2.11-CSCtz29665_4.2.2
