LMS 4.2 : Temperature OutOfRange
hairul_cisco
Hello, I keep receiving below alert from LMS:
EVENT DESCRIPTION       = OutOfRange::Component=TEMP-1.1.1.1/21856 [module-5 QEng1Sn2(s11)-module-5 QEng1Sn2(s11)];ComponentClass=TemperatureSensor;ComponentEventCode=1079;HighThreshold=40.0  DEGC;Status=OK;CurrentValue=41.0  DEGC;RelativeTemperatureThreshold=20.0  %;entS
NOTIFICATION ORIGINATOR = Fault Management Module
From the alert, i understand that the high threshold is set to 40, but when i checked on N7K i found that this threshold is set differently.
N7K# sh environment temperature
Module       Sensor                    MajorThresh        MinorThres        CurTemp          Status
5                QEng1Sn2(s11)       115                     105                     41                    Ok
Can someone give me insight why this is happening? I assume the device (N7K) will only send the traps only if the temperature exceeding the predefined value which is 105. Now I'm receiving this alert for almost 2000 alert per day. I tried increase the RelativeTemperatureThreshold from 10% to 20% but does not help.
Thnak you
I asked the TAC engineer, and here is the work around from them:
To solve this issue , please try the below :
1.       Stop daemon manager : net stop crmdmgtd
2.       Take a backup of oid2type_cisco.conf file (progra~2\CSCOpx\objects\smarts\conf\discovery\oid2type_cisco.conf)
3.       Modify the entry for Cisco Nexus 7000  in oid2type_cisco.conf file (progra~2\CSCOpx\objects\smarts\conf\discovery\oid2type_cisco.conf)  as shown below
# Cisco Nexus 7000
.1.3.6.1.4.1.9.12.3.1.3.612 {
    TYPE = Switch
    VENDOR = Cisco
    MODEL = N7K-C7010
    CERTIFICATION = CERTIFIED
    CONT = Cisco-EntityRF-Switch
    HEALTH = Nexus-Entity-EntSensor
    BRIDGE = Cisco
    NEIGHBOR = Cisco-Cdp
INSTRUMENTATION:
    Environment                         = CiscoEntityFRU:DeviceID
    Card-Fault                          = CiscoEntityFRU:DeviceID
    CPU/Memory                          = CiscoSystem:DeviceID
    Interface-Fault                 = MIB2
    Interface-Performance           = MIB2
    Port-Fault                      = MIB2
    Port-Performance                = MIB2
4.       Start daemon manager : net start crmdmgtd
5.       Remove, re-add and rediscover the device.
Shek Leung Chan
I have same issue as well, and my nexus 7000 is using NX-OS ver 5.2.3, shown as below:
Event_Description
OutOfRange
Device IP
10.100.1.2
Device Type
Switches and Hubs
Fault Last Updated At
31-Jul-2012 15:48:03
Component
TEMP-10.100.1.2/21857 [module-5 QEng1Sn3(s12)-module-5 QEng1Sn3(s12)]
Component Class
TemperatureSensor
Component Event Code
1079
Current Value
46.0  DEGC
Event Category
Environment
Event Source
DFM
High Threshold
45.0  DEGC
Relative Temperature Threshold
10.0  %
Status
OK
ent Sensor Value
46
hairul_cisco
Additional info related to my first post:
I noticed this problem only affecting Nexus 7000 Supervisor module-1X.
And I'm running NX-OS 6.0(2)
# Cisco Nexus 7000
    TYPE = Switch
    VENDOR = Cisco
    MODEL = N7K-C7010
    BRIDGE = Cisco
INSTRUMENTATION:
    Port-Fault                      = MIB2
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
