LMS 4.2 upgrade to LMS 4.2.1 on Soft Appliance
Michel Legare
I try to upgrade LMS 4.2 to LMS 4.2.1 on a soft appliance and i got this error.
To upgrade from LMS 4.2 to LMS 4.2.1:
lms/admin# conf t
lms/admin(config)# repository myrepo
lms/admin(config-Repository)# url disk://opt
lms/admin(config-Repository)# end
lms/admin# application upgrade Cisco_Prime_LAN_Management_Solution_4_2_1upgrade.tar.gz myrepo
Save the ADE-OS running configuration?(yes/no) [yes]? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Initiating Application Upgrade...
% Local file not found
lms/admin#
Any idea ?
Thank you
Michel
2 Accepted Solutions
mbilgrav
Level 3
Level 3
it mean that the file cannot be found.
Readme states:
Before creating repository copy the Cisco_Prime_LAN_Management_Solution_4_2_1.tar.gz to
local disk partition
please note LOCAL DISK partition !
So try copy your file to the correct location, and retry the process. also you may need to "chown" on the file, depends ...
Martin
FYI
I have this on mine installation;
LMS4/sysadmin# show running-config | b repo
repository app_repo
  url disk:
repository lms421
  url disk:
LMS4/sysadmin# dir
Directory of disk:/
  602468912 May 29 2012 01:06:54  Cisco_Prime_LAN_Management_Solution_4_2_1.tar.gz
      16384 Jul 18 2011 06:25:17  lost+found/
       4096 Jun 06 2012 09:54:01  patchtest/
           Usage for disk: filesystem
                  755847168 bytes total used
                 6950563840 bytes free
                 8125841408 bytes available
yours is on disk://opt/ - no go !
And with 2x / (?)
mbilgrav
Level 3
Level 3
Readme states:
Martin
FYI
repository app_repo
  url disk:
repository lms421
  url disk:
LMS4/sysadmin# dir
Directory of disk:/
And with 2x / (?)
This command refer to the IOS flash. It was my error.
