04-21-2009 05:10 AM
Is it possible to integrate the LMS and CSM using multi-server installation?
I would like to achieve the following things:
1. common DCR (master on LMS Server)
2. Single-sign-ON (SSO) with ACS authentication
3. RME on LMS Server
Solved! Go to Solution.
04-21-2009 09:27 AM
Yes, this is possible. Just make sure the server running the latest version of Common Services is the DCR and SSO master. Since you want to do ACS integration, BOTH CiscoWorks servers must also be integrated with the same ACS server(s).
04-21-2009 09:27 AM
04-21-2009 10:27 PM
Thank You.
