Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LMS and CSM multi-server installation
Is it possible to integrate the LMS and CSM using multi-server installation?
I would like to achieve the following things:
1. common DCR (master on LMS Server)
2. Single-sign-ON (SSO) with ACS authentication
3. RME on LMS Server
1 ACCEPTED SOLUTION
Re: LMS and CSM multi-server installation
Yes, this is possible. Just make sure the server running the latest version of Common Services is the DCR and SSO master. Since you want to do ACS integration, BOTH CiscoWorks servers must also be integrated with the same ACS server(s).
Thank You.
146
