Community Member
Lms Data Purging
According to my knowledge, Purging is the word related for jobs, config backup
probing at regular intervals of hours
is there any other terminology
i m trying to get hourly backup of devices , how can it be scheduled,
i observed the below logs , but icouldnt trace out what is it
E:\CSCOpx\files\rme\jobs
Results for Job : 1129
Job Status : Job Succeeded
Job Started at : Fri May 29 09:05:02 IST 2009
Job Ended at : Fri May 29 09:05:09 IST 2009
Successfull : 66
Failed : 0
Paritally Failed : 0
Pending : 0
Not Attempted : 0
Result for Device : Hostname
Execution Status : Job Execution Successful for device
Execution Message : CM0110 Purge policy is not enabled. Action: Enable purge policy and try again.
1 REPLY
Re: Lms Data Purging
If you mean config backup, go to RME > Config Mgmt > Archive Mgmt > Sync Archive, and schedule a job using the Group Selector. This will create a job using the selected group. If that group changes, then the job will run against the set of devices in the group at the time the job is executed.
106
