Community Member
LMS device package
My device update is failing with the following error :
ERROR: Error while installing (LibInventory): /opt/psu_download/rme/LibInventory.zip cannot be installed because, the current mdf version:1.30 is LESS THAN the minimum required mdf version:1.32.
I could not find mdf 1.32.
Please check and suggest.
-Thanks
Re: LMS device package
It should be available from Common Services > Software Center > Device Update. Check the box next to Common Services, and download the available MDF update.
Community Member
Hi Jclarke,
When i try this I get info message as :
All the available package(s)at source location are already installed.
We already have mdf 1.30. Is there a known problem for CS to get mdf 1.32?
Can we get it directly from CCO?
-Thanks
I was able to get it via Software Center. If you're having problems, you can also download it directly from http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one .
434
