LMS Device Packages for IPS 4260 and WAE-512/612
john.caterino
I am running LMS 2.6
Common Services 3.0.6 (MDF 1.23)
Campus Manager 4.0.12
RME 4.0.6
CiscoView 6.1.5
I can discover the IPS 4260 and WAE-512/612 devices and their OID's show up in Campus Manager however I can not manage them or view them because they are unknown.
Are these devices capable of being managed in RME/CiscoView and which files do I need to download to get the device packages?
any help appreciated !!
5 Replies 5
Joe Clarke
What are the sysObjectIDs of each of these device types?
here is what shows in the device
discovery report.
18. .1.3.6.1.4.1.9.1.743
112. OE612 .1.3.6.1.4.1.9.1.777
113. OE512 .1.3.6.1.4.1.9.1.776
The 743 device is not supported. The two WAE devices are supported in CE500 package version 3.2 for RME 4.0.6. They are also supported in Campus Manager 4.0.11 and higher.
[Edit]
There is no CiscoView support for any of these devices.
jclarke you rock!
Once again I apprecaite your assistance!!!
If there is a way that I should have been able to determine that on my own, please let me know. I hate bugging you for minor issues and I tried serching the device support docs and release notes online.
You can search Cisco.com for the various device support documents for each of the LMS applications. For example, here is the one for Campus Manager:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_campus_manager/4.0.6/device_support/table/cm406sdt.html
