Community Member
LMS error
I am having a issue with LMS. I recieve this error when I go to netconfig.
URN_NOT_FOUND : urn "JRM" : Not found
This happens when I go to look at the jobs I have already created in netconfig. I am not able to view those jobs although they do still run as it the jobs set to reboot my routers still work.
Dave
Re: LMS error
Please provide the output of the NMSROOT/bin/pdshow command as well as the OS on which LMS is installed.
Community Member
Re: LMS error
The OS is server 2003 I am not sure how to aquire the output from the NMSROOT/bin/pdshow
Where do I get that from?
Re: LMS error
Run the command, "pdshow" and get the output. Also, include the jrm.log.
Community Member
Re: LMS error
Here is the pdshow
Community Member
Re: LMS error
Here is the jrm.log
Dave
Re: LMS error
I have never seen this message before. Please provide your NMSROOT\lib\classpath\md.properties file and the output of:
ping 127.0.0.1
Community Member
Re: LMS error
Not sure how to get this for you either.
NMSROOT\lib\classpath\md.properties ?
Also when I open anything in even outside of RME like to use'netshow' I get the same errorwhen opening it. Do I have a JAVA problem maybe?
Re: LMS error
NMSROOT\lib\classpath\md.properties is a file on the file system. Attach that file to this thread. NMSROOT is the path into which you installed CiscoWorks.
Community Member
Re: LMS error
Here is the file
Dave Peter
Re: LMS error
Okay, given this file, jrm will attempt to create a connection to localhost on TCP port 42340 to register with dmgtd. Therefore, I need the output of the following command:
C:\progra~1\cscopx\bin\perl C:\progra~1\cscopx\bin\resolver.pl localhost
I also need the output of the ping 127.0.0.1 command I requested previously.
Community Member
Re: LMS error
The ping on 127.0.0.1 came back 100% I have added the text from the resolve file. I do not see a local host file in that location or the 'perl' file I have a 'perl.exe' and a 'perl.dll' ?
#!/opt/CSCOpx/bin/perl
# Copyright (c) 2001-2002 Cisco Systems Inc.
# All rights reserved
use CRM;
BEGIN {
require lib;
import lib "$ENV{'NMSROOT'}/objects/perl/install/";
# check for number of arguments
if ( @ARGV < 1 ) {
print "Usage : perl resolver.pl addr1 [addr2] ...\n";
exit(1);
$CLASSPATH = "$ENV{'NMSROOT'}/www/classpath/com/cisco/nm/cmf/desktop";
#print $CLASSPATH . "\n";
my $i = 0;
my $s = "";
# construct a string of hostnames separated by space
while ( $i < @ARGV ) {
$s = $s . " " . $ARGV[$i];
$i++;
#execute java class file
system ( "$ENV{'NMSROOT'}/bin/cwjava -cp:p $CLASSPATH TestRes $s");
Re: LMS error
You were supposed to run the command:
Then capture the output and attach it.
Community Member
Re: LMS error
Also when I excecute perl in a command prompt it just goes to a curser. I do not get any output.
Dave
Re: LMS error
Please provide the list of contents of C:\progra~1\cscopx\bin (i.e. the output of "dir C:\progra~1\cscopx\bin").
Community Member
Re: LMS error
Hey sorry about that:) Here is the file for you
Re: LMS error
If you execute:
pdexec jrm
Does the jrm process come up? That is, if after running the pdexec command, run the command "pdshow jrm". What is the output?
Community Member
Re: LMS error
Yes it states it is running normally
Re: LMS error
Good, this may have just been a transient error, then. Restart dmgtd from the command line:
net stop crmdmgtd
net start crmdmgtd
You should be up and running. If you still have problems, one thing that could cause processes not to initialize property is a server that does not meet minimum requirements. Given the apps you have installed, your server must have at least two physical CPUs (or cores) and have at least 2 GB of memory with 4 GB of page file.
Community Member
Re: LMS error
Nope, I get the same error after restarting them ?
Re: LMS error
So what are the hardware stats on your server?
Community Member
Re: LMS error
2.8 gig xeon and 1 gig of RAM
Re: LMS error
That's the problem. You do not have enough memory to start LMS. You need to add another 1 GB of physical RAM just to get the suite of applications to start.
Community Member
Re: LMS error
hmmm... I have been using this suite for 3 years now. I wonder why it would have the problem now? Could it have been struggling along and then just not had enaugh to do it anymore?
Re: LMS error
I know for a fact that entire bundle (LMS 2.5 and higher) cannot start on 1 GB of RAM. It must have 2 GB with 4 GB of backing swap. Without this, processes will fail. These requirements were not as high under LMS 2.2 which could explain how you were running LMS successfully for so long.
Community Member
Re: LMS error
I have some RAM here that I am tring to work.
I will respond as soon as I do. That makes perfect sense about being on 2.5 and up.
Dave Peter
Community Member
Re: LMS error
OK I put in 2GIG and I still have the error. I do have 4GIG swap also I thought for sure that was going to work. I am sending you a screen shot of the error.
Re: LMS error
Send the output of "set" from a DOS command prompt as well as the C:\progra~1\cscopx\MDC\etc\regdaemon.xml file and the current jrm.log. Note: if the data in regdaemon.xml is too sensitive to post, open a TAC service request, and include all of this information.
Community Member
Re: LMS error
Ok here are the files you requested. Unfortunatly I do not have TAC on the LMS suite anymore.
Community Member
Re: LMS error
Wow you are not going to believe this. I went through all the JRM files XML and html and some other ones. I just opened them and read them to see what they did. Then I went back and logged into Cisco Works and went to the netconfig jobs and netshow jobs and everything works! Not sure what happened? I made it recognize the files again after I opened them?
Dave
240
