LMS installation
after install the common service and begin to install the campus manager and during the installation it give me message that : "there is no component selected"
note: there is no list to choose from it.
note2: this step come after write down the password and choose the licence file.
Re: LMS installation
On what platform are you installing? Are there any other details in the installation log? What license choice did you make (i.e. actual licese file, PIN/PAK, eval)?
i install it on server 2000, the licience that i used is the actual licence file no pin/ no pak no evaluation.
so i don't know what is the matter
I am unable to locate this error in the source. So make sure the license file is valid. Since this is Windows, make sure you're doing the installation as a local Administrator, and that the TEMP and TMP environment variables point to a short path such as C:\TEMP.
If you still have problems after verifying the things above, check the installation log file for errors.
109
