I'm currently using LMS 3.1 and Campus Manager v 5.1.0
I've several remote sites connected through VPN-tunnels (DMVPN + eigrp).
From the LMS server there is connectivity to all Cisco devices.
In the picture you can see the links between a router and a switch in the remote sites.
But there is no links between central office router and remote sites routers in Campus Manager Network Views.
I've enabled CDP in the routers' tunnel interface but the no results.
Is it possive to see all the sites as a single network (with the connections between routers) ?
Thanks a lot!
