Webcast-Catalyst9k
LMS loaded on second drive.
Is is possible to load LMS on a drive other than C:? If so how do you do it?
1 REPLY
Re: LMS loaded on second drive.
Select a custom installation, then you can install LMS onto any local drive you wish.
96
