Webcast-Catalyst9k
LMS not Booting - Stuck in Hardware Diagonistic stage
Hi ,
    i am facing problem with LMS device so i am posting here for a solution,
Today i am not able to ping LMS server so i checked the server , the server was stuck in Hardware Diagnositic stage . I have done a restart also ,but same error continues
1 REPLY
Hi Mohammed,
Attached the Screen shot of the Error
If it is a Windows Server. Change the STARTUP type ( go to Run type > Services.msc) from Automatic to MANUAL
and reboot the server.
once the server is back change the startup type to Automatic and START the DAEMON MANAGER (net start crmdmgtd)
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
193
