Webcast-Catalyst9k
LMS portal and ACS
The customer has installed LMS 3.1 on the Windows server. He integrated this LMS with ACS. The users can change the private views of LMS portal. The customer has only one question. Where is saved information about user settings of LMS views? I hope that the private LMS views are saved by user. So when one user logs into LMS, he can see only his portlets in LMS portal. So other user can see other portlets in his view... Is this information stored on the LMS server or in the ACS server? Can the customer modify these user settings about private views? Thank you.
1 ACCEPTED SOLUTION
Re: LMS portal and ACS
This is not possible. I have raised this with development when LMS 3.0 was first released. This is being planned for a future release.
The data is stored in a flat-file database in NMSROOT/MDC/tomcat/webapps/cwportal/db on the LMS server. The data cannot be modified directly.
Thank you. How should it be changed indirectly :) Is it possible? Because the superadmin wants to change the private views for all users to default view.
123
