06-18-2009 08:32 PM
Cisco works LMS portal showing devices not configured in ACS. also not able to delete those devices pls help..
06-18-2009 09:08 PM
When LMS is integrated with ACS, all devices to be managed by LMS but be configured as network clients of the same ACS server. Once you configure those devices in ACS, they will be visible in the LMS device selectors (as well as deletable). Alternatively, if you just want to delete the devices from LMS, you can temporarily break the ACS integration with the command:
NMSROOT/bin/perl NMSROOT/bin/ResetLoginModule.pl
Then clean up DCR, then re-enable ACS integration.
06-18-2009 09:25 PM
I have added the devices in ACS but still not showing in common services whehther i need to run device discovery again.
06-18-2009 09:45 PM
Try restarting ACS and CiscoWorks Daemon Manager.
06-19-2009 02:28 AM
Thanks it's working..
