LMS Prime 4.3 Shell PW
                   Is there a way to recover the  shell password on the sysadmin cli for LMS prime soft appliance running on VMware ? Thanks
  • Network Management
1 ACCEPTED SOLUTION
By default, the shell will be enabled with sysadmin password. If you want to
change the shell password, use Vsphere console and enter the command
shell_enable in sysadmin mode. On using Vsphere console, you will not have
to enter the old password whereas on using other console, you will be
prompted to enter the old password.
Please refer to the following link on this matter:
http://tools.cisco.com/squish/Eb0D6
Hope this will help.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks-
Afroz
Works fine. Thanks!
256
