LMS Prime: Disabling Alterts for BRI Interfaces
i revceive a lot of Alerts of BRI Interfaces on a router.
EVENT ID               = 000072X
TIME                   = Tue 08-Nov-2011 16:06:44 CET
STATUS                 = Active
SEVERITY               = Critical
MANAGED OBJECT         = 192.168.25.4
MANAGED OBJECT TYPE     = Routers
EVENT DESCRIPTION       = OperationallyDown::Component=IF-192.168.25.4/36 [BR0/0/0:1];ComponentClass=Interface;ComponentEventCode=1075;AdminStatus=UP;DuplexMode=FULLDUPLEX;OperStatus=DOWN;MaxSpeed=64000;Type=DS0;Mode=NORMAL;IsFlapping=false;InterfaceCode=CODEUNKNOWN;LastChang
NOTIFICATION ORIGINATOR = Fault Management Module
how can i get rid of them?
i already searched in Monitor > Fault Settings > Setup > Threshold Settings
but i didn't found where i can disable Operationally Down messages for certain interfaces.
thanks
alex
The faults you get come from the bearer-channels. You don't want to monitor these. You do want to monitor the signaling interfaces to know the BRI or PRI is working.
Check the end of this post where Joe explains the syntax of a file you can use to filter these interfaces when DFM faultmanagement discovers the devices.
https://supportforums.cisco.com/message/3431258#3431258
Cheers,
Michel
Hi Michel,
i tried to modify the tpmgr-param.conf file and added this entry IFDescrPattern-.1.3.6.1.4.1.9.1.1045 *~Bearer Channel*. But still I receive the messages.
#This is an example of how to restrict the creation of ports for a
#specific sysObjectId based on the ifType:
#IFTypePattern-SwitchPort.1.3.6.1.4.1.9.1.501 53
# Add Fiber Channel port (56) for MDS devices
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.380 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.376 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.375 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.414 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.411 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.442 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.612 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.12.3.1.3.719 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.1.475 6|26|56|62|69|117
IFTypePattern-SwitchPort.1.3.6.1.4.1.9.1.407 6|26|56|62|69|117
I think the patern should be like this:
IFDescrPattern-.1.3.6.1.4.1.9.1.1045 ~*Bearer Channel*
Is it only this sysobject ID send the message?
Cheers
Michel
Hi Michel,
yes its the only Router which has BRI Interfaces, all the others have PRI and they don't send this kind of messages.
Do i have to restart the daemon manager after changing the parameter?
regards
alex
Yes,
I think a rediscovery of the device(s) is required as well.
Cheers,
Michel
673
