LMS2.5 and UT
Is there an option in UT that it can display more than 50 rows? It is kind a annoying that it doesn't show the full table like it used to or may that I'm missing something.
Thanks.
  • Network Management
1 REPLY
Silver
Re: LMS2.5 and UT
If you want to see the full table then you better use the DBreader page. This is the perl SQL interface to the databases.
The table EmbuUserTracking in the ANI database has got what you are after.
The limit here is 3000 I think but it can be adjusted.
Michel
104
