Community Member
LMS2.5 Changing device credentials
I have 100+ switches managed through LMS 2.5. We are going to change the "primary credential" from a telnet password to a TACACS userid and password. Is there a way to broadcast this change instead of going into the "Credential Template" for each switch to make the change?
1 ACCEPTED SOLUTION
Red
Re: LMS2.5 Changing device credentials
Go to Common Services -> Device and Credentials -> Device Management
Select the devices that have the same credentials
Click on Edit
This will open up the Device Properties window
On the left side of the frame, you will see the list of devices you selected, and underneath it will say:
"Select a device above then edit its information"
Do NOT select any device, simply click on Next
Enter the proper credentials and click on Finish
That should take care of all the devices at the same time.
Red
Are you trying to use LMS 2.5 to modify the configs?
Or are you simply asking how to update the credentials that LMS 2.5 will use to communicate with the dveices after the change is made?
Community Member
How to update the credentials that LMS 2.5 will use to communicate with the devices after the change is made. Thanks
Red
Click on Edit
Silver
So either you select 100+ devices in the tree, or you find a way to put these devices in a group or a few groups and select these.
Cheers,
Michel
113
