LMS2.5: Upgrade License
fdeutschmann
we have the same problem........
I installed the LMS 2.5 + Dec2005-Patch (Solaris2.9) and when I start RME/CM/DFM, I get the following Warning :
"This softwre is provided for evaluation purposes only and will be operational for 90 days. If this...."
When I go in the licensing tab of Common services, I see RME/CM/DFM/IPM with a status purchase, size unlimited, and expiration date never.
I stop the license server (pdterm LicenseServer)
-> delete all *.lic files in Directory /opt/CSCOp/etc/licenses
-> pdexec LicenseServer
-> Update the LMS**.lic file from the UI from Server->Admin-> Licensing (opt/LMSLicense/LMS***.lic)
=Warning/ Info:
You have added an upgrade license. But the Proof of Purchase is not validated for upgrade license.
Please run validateupgrade to validate the upgrade.
-> O.k next Step:
# ./validateupgrade
ld.so.1: validateupgrade: fatal: libstdc++.so.3: open failed: No such file or directory
Killed
CWLMS-2.5-MR-K9
LMS 2.x Minor Update Kit to LMS 2.5 UR - Incl May05
Thanks for your help.
Franz
stschmidt
Please follow the next steps in
order to fix your issue.
Step 1 Go to C Shell by running the command csh.
Step 2 Set the environment using the command:
setenv LD_LIBRARY_PATH /opt/CSCOpx/objects/db/lib:/opt/CSCOpx/lib:/opt/CSCOpx/MDC/lib
Step 3 Change the directory to /opt/CSCOpx/bin using the command:
cd /opt/CSCOpx/bin
Step 4 Run the CLI script:
./validateupgrade
Hello stschmidt,
I applied the solution you provide me,and it worked fine.
Thanks for your help. :-)
Regards.
Franz
jsteffensen
We also have the same problem on solaris 2.8..
I'll try the checklist wich was provided in the thread. Hope it works for us as well.
Greetings
Jarle
