Community Member
LMS2.6 integration with Cisco ACS
Hi all,
Does anyone know where I can find instructions to integrate ciscoworks lms2.6 with ACS v4.1? I've only been able to find info on integrating lms3.0.
1 ACCEPTED SOLUTION
Re: LMS2.6 integration with Cisco ACS
ACS integration with LMS 2.6 is only supported up to 4.0. Attached is an HTML document that TAC uses as a rough guide on setting up ACS integration. Many of the steps documented at http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html apply to LMS 2.6 and ACS 4.0 except for the fact that with LMS 2.6, you must create the Super Admin group in ACS manually.
Community Member
Thank you. I really appreciate the info.
Anonymous
N/A
Hi jclarke, I have LMS 2.6 and want to integrate with ACS version 4.1(1) build 23
is it possible? If not, do I need to upgarde the LMS to 3.x?
yanic
You need to upgrade to LMS 3.0 for this to be officially supported.
118
