Community Member
LMS2.6 upgrade - Realtime
I am upgrading LMS 2.5.1 to 2.6 using the single update CD. The following has happened:
INFO: performing prerequisite: cm: /cdrom/lmsupd2_6_sol/info/cm
cat: cannot open /tmp/cscotmp/new.depend
INFO: total size (MB) required = 1002
INFO: performing prerequisite: CSCOdfmz: /cdrom/lmsupd2_6_sol/packages/CSCOdfmz/
WARNING: Exiting installation beyond this point might result in system instability.
Do you want to continue the installation? (y/n) [y]:
Should I worry about this or just keep going?
Re: LMS2.6 upgrade - Realtime
Keep going, everyone sees this message, and it alone does not represent a problem.
Community Member
Rolling forward then.
106
