LMS3.0.1 crash
This morning I tried to get into CW and found that it had crashed. The page I was getting was Server Not REady. I tried to stop/start services but after about 30 minutes many parts did not come back like IPM and DFM. I noticed that Tomcat was using 400mb of memory and would not stop.
Is there a log that I can look at to find out what may have happened??
thanks
tony
Silver
Re: LMS3.0.1 crash
Well yes there are quite a few logs to look at under /var/adm/CSCOpx/log/ (solaris) or SystemDrive:\Program Files\CSCOpx\log\ (wndows) with the logs listed by daemon name, but first you want to check the status of your system daemons using pdshow.
Re: LMS3.0.1 crash
I am running this on Win2k3.
I ended up stopping the services and rebooting the server which seemed to fix it but I am worried that this happens again and I don't know what happened.
i would like to try to figure it out.
Silver
Re: LMS3.0.1 crash
pdshow is the status checker for the daemons that run everything on the system. If you can't determine what the state of the system is how can you troubleshoot ? Current status of the application daemons (never started, administraror shut down, running with busy flag set, etc) along with the log files can tell you exactly whats going on.
109
