LMS3.0.1/CS: discovery always running
Manytimes, discovery jobs is always running and doesn't stop.
Discovery is schedule to run each hour. Usually, it takes 20 minutes.
You can find logs and config file.
Log file was huge, I split it.
Thanks, Elisabeth
1 REPLY
Re: LMS3.0.1/CS: discovery always running
You are most likely seeing one of two bugs CSCsv42110 and/or CSCsk88625. The bugs are not fully fixed until LMS 3.2. However, if you upgrade to LMS 3.1, a cumulative discovery patch is available from http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one for bug CSCta35248 which will fix these issues. Of course, it would be better to move directly to LMS 3.2.
123
