11-24-2010 06:36 AM
I have created a jobs in NetConfig and i have the following Message :
Message: Deploy command partially failed (Primary Login Succeeded / Primary Enable Succeeded)
The Task is Adhoc and i have added 3 instances.
Adhoc_1
file prompt quiet
rtest242(config)#
Adhoc_2
copy system:running-config ftp://user:pass@172.25.77.178/reseau/
Adhoc_3
no file prompt quiet
rtest242(config)#
1. The config is correctly copied on the server.
2. If i'm created 3 tasks, its run without erreur message.
Why i cant do this in 1 job.
Thx
11-25-2010 07:11 PM
Enable ConfigJob debugging under RME > Admin > System Preferences > Application Loglevel Settings. Then re-run the failing job and post the job directory from NMSROOT/files/rme/jobs/NetConfigJob.
11-26-2010 07:29 AM
11-26-2010 09:58 AM
Your template is out of order. You've disabled "file prompt quiet" before the copy command runs. Instead of trying to disable interactive prompts, just use Netconfig's interactive prompt handling feature to do what you want. Change your template to be 100% enable mode with these contents:
Where the trailing rtr-config is the value you'd enter at the second prompt.
11-26-2010 11:40 AM
what
and rtr-config ?
thanks
11-26-2010 11:42 AM
This denotes the prompt and response. When Netconfig sees "
11-26-2010 12:38 PM
its good
Michel
