Webcast-Catalyst9k
LMS3.1 - RME - Catalyst 6500 or CE500 Not Recognized
RME Device Credential Verification Job and the RME Config Archive Job fails for Catalyst
6500s and CE500s. The Common Services is able to discover the devices. RME device
Inventory job does NOT fail for the same devices. We are able to view the devices with
Cisco View - Chassis View. The following are the errors we get for the Config Archive
Job:
Failed Device Error for Catalyst 6500s:
CM0056 Config fetch failed for 10.1.0.1 Cause: CM0204 Could not create DeviceContext for
871 Cause: CM0206 Could not get the config transport implementation for 10.x.x.x Cause:
CM0202 Could not access 10.x.x.x via SNMP. Action: Check the Read Community string Action:
Check if required device packages are available in RME. Action: Check if protocol is
supported by device and required device package is installed.
Failed Device Error for CE500s:
CM0056 Config fetch failed for 10.x.x.x Cause: CM0204 Could not create DeviceContext for
996 Cause: CM0206 Could not get the config transport implementation for 10.x.x.x Cause:
Action: Check if required device packages are available in RME. Action: Check if protocol
is supported by device and required device package is installed.
Device Credential Verification jobs come back failed with error message stating:
Device Not Supported.
Need assistance to figure out what needs to be done. If device package updates are
needed, need assistance figuring out which device packages to download and how.
Our LMS3.1 is running on a Solaris platform.
1 ACCEPTED SOLUTION
Blue
Re: LMS3.1 - RME - Catalyst 6500 or CE500 Not Recognized
Here're the three device pkgs that should cover the two named models:
Cat6000IOS
Cat6000
CE500
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/device_support/table/lms31sdt.html
1 REPLY
Blue
Cat6000IOS
Cat6000
CE500
188
