LMS3.2/CWA1.2.0: Device troubleshooting -> Timed out
Customer has LMS 3.2 on windows 2008. They have this issue since they have upgrade to LMS 3.2.
He has a multi-server config. Both master and slave have the same issue.
When trying to launch Device troubleshooting, cu has an error message "Error : Server Discovery timed out. Please try again later.".
We have enabled debug on CWA, you will find log file.
We have reinitialized cwa db only on master, I don't know if we need to reinit on slave.
I didn't find bugid for CWA.
Pdshow seems good.
Cu told me that they didn't change hostname.
Many thanks for your help,
Elisabeth
1 ACCEPTED SOLUTION
Re: LMS3.2/CWA1.2.0: Device troubleshooting -> Timed out
Hi Elisabeth,
seems that you are hitting "CSCsw82367    CWA1.2:OpsXMLRuntime taking more time to come up. " Please try to restart CWAPublisher services or run CWAPublisher.exe manually after the daemons are up.
Hi Elisabeth,
Hi Svetlana,
You are right, I had opened a SR at tac and they gave me the same response .
Many thanks, Elisabeth
363
