11-17-2010 03:00 AM
we use LMS3.2 (windows single-server) for ~4500 devices and have a problem with log rotation.
That's our configured log roation:
Name with location | Size (kb) | Format | No.of Backups | ||
1. | D:\CSCOpx\log\dcrclient.log | 102400 | gz | 3 | |
2. | D:\CSCOpx\log\ICServer.log | 102400 | gz | 3 | |
3. | D:\CSCOpx\log\syslog.log | 1024000 | gz | 5 |
The backup directory is the same as the usual log directory. The size of the 3 files is already bigger than the configured size in log roation, see:
dcrclient.log 2,1 GB
ICServer.log 1,1 GB
syslog.log 9,7 GB
After the log roation configuration we restarted the daemon manager, but it's not working. There are no backup files created and the 3 files are still growing.
Hendrik
Solved! Go to Solution.
11-17-2010 04:02 AM
After you configure the log rotation you need and restart the daemons, you need to schedule the job. The schedule buttong is available under
Common Services -> Server -> Admin -> Log Rotation.
11-17-2010 04:02 AM
