Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LMS3.2 (RME 4.3.0) 3560v2
Does anyone have an update on the timeline of support for 3560v2 switches in RME4.3
Re: LMS3.2 (RME 4.3.0) 3560v2
What is the exact sysObjectID of this switch?
1.3.6.1.4.1.9.1.1024
This device is supported now in Cat3560 package version 7.1. However, we have an issue. It appears that the Cat3560 package which came with RME 4.3.1 reports itself as 7.1, but does not include support for this device. The Cat3560 7.1 package on Cisco.com right now DOES support this device. I'm trying to get this sorted out now.
Standing by for an update.We did a large deployment of 3560v2s only to be unpleasantly surprised by (lack of) LMS support...
If you have RME 4.3.0, you can go to Common Services > Software Center > Device Update, and download and install all available updates for Common Services and RME. That will give you 3560v2 support. If you have RME 4.3.1, you will need to wait a little while longer. New packages are forthcoming.
we are running 4.3.0
I have succesfully installed all packages except LibInventory 3.1.3
When trying to install I get error message:
Number of Packages Selected for Install : 1
For Product(s) : Resource Manager Essentials
Install Invoked by user : rcierny
The Package(s) Selected for Install :
LibInventory
ERROR: Error while installing (LibInventory): C:psu_download
meLibInventory.zip cannot be installed because, the current mdf version:1.30 is LESS THAN the minimum required mdf version:1.32
No package(s) to install for : Resource Manager Essentials
3560v2 devices still not showing in CS
What version of the Cat3560 do you have loaded? As for installing the LibInventory package, you need to get the latest MDF for Common Services. That is also available from Software Center > Device Updates (for Common Services), or from http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one .
30. Cat3560 7.1 Cat3560 device package
What exactly do I need to download?
This is the correct package, and I know it has the sysObjectID for this switch. Post the list of contents under NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs.
Hi jclarke. Do have any new infos when the new packages are available? I have 4.3.1 and i'm also waiting for 3560v2 support.
Support for 4.3.1 should be coming early next month.
337
