LMS4.2.4: jnlp cant start Topology View
What can avoid the launch of the jnlp for the Topology View in IE and Firefox?
Topology View was working till:
Since activating https on LMS-server, Topology View Java Applet doesnt start anymore from the local browser at LMS server.
Deactiving https back to http:1741 doesnt improve.
Behaviour: After call TopoView, the TopologyServer.jnlp will be downloaded, you see the Applet short 1/10 of second flashing and then nothing happened as were something in the OS drive down the jnlp-starter immediatly.
1. both browsers are set to open and not save jnlp Apps
2. DEP is off
3. I deinstalled all JRE's, rebooted and installed cisco-jre1.7 again. In the moment of deistallation the jre installer, show sone jawa.exe are open - very likely all try's of opening Topology Services
4. checked that LMS is on trusted site
5. nothing seen in Windows event log
6. stopped AV
What could this new behaviour caused by?
Steffen
1 REPLY
Hall of Fame Super Silver
Re: LMS4.2.4: jnlp cant start Topology View
Try opening the Java console (from the control panel applet) prior to launching. It may have some useful output indicating the root cause.
193
