09-26-2013 07:39 AM
In LMS4.2.0 Device Selector is overall working except of the whole reporting with always 0 devices selected. Do you have any ideas what to can do?
thx for hints, Steffen
09-26-2013 08:02 AM
Hi Steffen,
Try to Reboot the server and check the issue again.
Your LMS is Installed on which OS ?
Thanks-
Afroz
09-26-2013 01:02 PM
its a Windows system
09-26-2013 08:41 PM
Steffen,
follow the below steps:
1.stop the daemon manager
2.Remove or rename the RME database transactional logs (rme.log) (if they exist):
# NMSROOT/ CSCOpx\databases\rmeng\rme.log
3.
NMSROOT/CSCOpx/database/rmeng> dbsrv10 –f rmeng.db
4. start the daemon manager
wait for 15 mins and check the issue again.
Thanks-
Afroz
09-27-2013 05:17 AM
Hi Afroj,
Thx for the procedure, but it doesnt fix the issue.
I also upgraded to LMS4.2.4, no improvement, cant use overall reporting.
Steffen
